GYT-R exhausts
Old Apr 28, 2004 | 01:43 PM
clover's Avatar
Default GYT-R exhausts
are these exhausts any good and do they sound alot better than stock,i'm thinking of getting one for my rap 350,because its the only one out.
Old Apr 28, 2004 | 02:07 PM
AlphaRaptor660R's Avatar
I have the gyt-r for my rappy. It's a pretty decent exhaust for my rappy. It has good low to mid range power, but seems to lack in the upper end. I think they might be a bit too loud though. They are definitely much louder than stock. They don't sound bad though. But I believe there is a quiet insert available for them now. I'd say wait around for a little bit and see if any of the other companies come out with something new...
Old Apr 28, 2004 | 02:15 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
you should give it a little time
I have a 1st generation(2001) GYT-R for my rappy,,,,,it is loud,,,,and they dont even make parts for it anylonger (although pretty happy with it). (I bought it used on ebay for $140 in perfect shape)
Wait till the market is flooded with 350 pipes...then take your pick
Old Apr 28, 2004 | 03:30 PM
maddog56's Avatar
The market is flooded with 350 pipes, they are called warriors. Most will be the same pipe for both models. Because the engine and the top end are the same, I see no reason why they should be significantly different. I dont believe the frame mounts have changed either. Only plastic issues should be noted.
Old Apr 28, 2004 | 03:33 PM
Bing's Avatar
Super Quad Patrol
so, a full warrior pipe fits a raptor 350,,,or just the slip on??
Old Apr 28, 2004 | 03:41 PM
maddog56's Avatar
From the raptor 350 that I saw there shouldnt be any plastic clearance issues with the pipes. The mounting brackets look to be in the same location. I have not bolted a warrior pipe up to the mini raptor, so I cannot say for sure. The slip ons do appear to work. I have seen some posts from others who have warrior slip ons on their raptor 350.
Old Apr 28, 2004 | 10:23 PM
Hebs's Avatar
Mine sounds saaaweet. Course it put the dB up to 102, from the stock like 86 or something.
Pehter
Oct 3, 2024 11:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
cboler9
Sep 24, 2015 08:35 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
