ATC 200X ELECTRIC STARTER
Old Apr 29, 2004 | 04:54 AM
GIMPED's Avatar
Default ATC 200X ELECTRIC STARTER
HI, CAN ANYONE HELP ME? MY COUSIN HAS A 1985 HONDA ATC 200X. ITS IN GREAT SHAPE EXCEPT THE KICK STARTER IS A PAIN IN THE @$$. (ESPECIALLY IF ITS COLD AND TAKES SOME GOOD KICKS TO GET GOING) I HEARD SOMEWHERE THAT THERE IS AN ELECTRIC STARTER KIT AVAILABLE FOR IT. IS THIS TRUE? IF SO COULD SOMEONE POINT ME IN THE RIGHT DIRECTION? THANKS FOR THE HELP!!!
Old Apr 30, 2004 | 03:05 PM
ThrashAndCrash's Avatar
Yes there is a kit. It runs over $200. I do not think they make them anymore. I have seen a couple on E-bay, but not very often. I will see if I can find a link for you. Why is the kick start a pain? Maybe your timing is a touch off? Are you getting a ton of kick-backs? I have the 10 1/2 to 1 piston in mine and it starts pretty good.
Old Apr 30, 2004 | 03:26 PM
Look Here! This is what you are looking for. This is a old link, but that is what it looks like.
Old Apr 30, 2004 | 10:34 PM
BeerSmurf's Avatar
I think the cheaper solution might be a little carb work.
Check for air leaks bad gaskets, o-rings etc.
Then adjust the Idle speed and mixture per the book.
A well adjusted X should be easy to start.
Old May 1, 2004 | 01:32 AM
GIMPED's Avatar
THANKS FOR THE HELP GUYS!!
GODsRebel
1) Engine problems..
11
Sep 8, 2015 12:07 AM
Pahuntman
Sep 5, 2015 11:07 AM
WesTech
11
Aug 11, 2015 07:55 AM
akbrewcrew
Aug 9, 2015 10:54 PM
raceware
Jul 30, 2015 06:59 AM
