ALWAYS needs the choke
Old Apr 29, 2004 | 05:10 PM
Shav0's Avatar
Default ALWAYS needs the choke
Latley my quad always seems to want the choke on to start. Even on hot days and after I have been riding, If I let it sit for 10 minutes or so it wont start until I turn on the choke. When I start it up with the choke on it will stall if I turn it off right away.
Anyone know what is causing this and how I can fix it?
Thanks
Junior_
Old Apr 29, 2004 | 05:13 PM
stevendsm95gst's Avatar
this happened on our lt80. I just turned the idle up a bit and never had to use the choke again.
Old Apr 29, 2004 | 05:19 PM
zslate's Avatar
yeah my warrior was like that just like steven said turn the idle up and you outta be good to go! Have a gooden'!
Old Apr 29, 2004 | 05:36 PM
Shav0's Avatar
alright, thanks
. . turn up the idle? Or the idle mixture screw?
Old Apr 29, 2004 | 05:52 PM
Shav0's Avatar
I tried turing up the idle screw but it didnt seem to effect the starting at all. I can understand why it would need to be choked after sitting for a day or two but not only 10 minutes. . . If I don't use the choke I can kick and kick and kick and it dosn't do nothing. But as soon as I use the choke it starts first kick. . .
hmmm...
Old Apr 29, 2004 | 07:35 PM
radfastdude7777777's Avatar
maybe you are in a mirror world and choke means not choked and vise versa[img]i/expressions/face-icon-small-shocked.gif[/img] or maybe the wire is defective or something
Old Apr 29, 2004 | 07:39 PM
wanaply21's Avatar
i dont think idle will do anything for start up cuz the bikes not running, mine does the same exact thing and i am pretty sure its just cuz its running lean but im not sure
Old Apr 29, 2004 | 08:37 PM
Shav0's Avatar
The choke adds more gas correct? This must mean that the bike will not start because it dosn't have enough gas or. . is lean. Maybe I will try to screw IN the mixture screw and see if that helps.
Thanks for the advice guys
Old Apr 29, 2004 | 08:53 PM
Hiram's Avatar
Also going bigger on the pilot jet helps
Old Apr 30, 2004 | 01:29 PM
hondabuster's Avatar
Sounds like your pilot jet is plugging up, or is too small, or the air screw is too lean.
