1999' Trail Blazer 250 HELP!!!
Old Apr 29, 2004 | 06:22 PM
xxxshiftxxx's Avatar
Default 1999' Trail Blazer 250 HELP!!!
I just installed new BUttons on my driven Cluth.. now i put it all back together and it goes into fwd and drives, but when i put it in reverse it sounds like the enging is boggin down, like something it holding it from moving... PLEASE help.. did i put the clutch back together wrong?/ any infor would be appriciated!! thanks
Will
Old Apr 29, 2004 | 08:17 PM
predRyda500's Avatar
Did you have the reverse over ride button on when you went in reverse...
Old Apr 29, 2004 | 09:10 PM
tbsleeper's Avatar
u gotta hold override!!! when u change the engagement its not gonna engage at 2000 rpms anymore!!
Old May 31, 2004 | 10:06 AM
Lunchlady5586's Avatar
When you assemble the secondary clutch you must push the clutch halfs together about an inch and rotate one clutch half 1/3 a turn. Now push together the halfs and put the circlip back on. I find this assembly easyist with the clutch on the floor and I hold it down with my knee (if you dont have the polaris press tool). If it is assembled correctly you should be able to turn the halfs in opposite directions and they should rebound back.
Old May 31, 2004 | 04:31 PM
Redbullssg's Avatar
The LUNCHLADY is correct, by putting a 1/3 turn you are putting the nessary preload on the spring/sheaves...
But wouldn't you think that if that were the case, that the primary would have to engage to grab and pull the secondary? YOu could have as much or as little preload on the secondary as you want but it will never go anywhere until the primary takes ahold of it.
did you happen to mess with the engine, or I should say carb at all? If you put the idle to high it would do the both of what you are talking about or if it is reving to high for that matter...
oliveiracarlos
19
Nov 11, 2015 05:49 AM
Steeldon
Sep 9, 2015 09:38 AM
craacker
Sep 9, 2015 04:32 AM
Steeldon
Sep 8, 2015 10:51 AM
spark1051
Utility ATVs
Sep 4, 2015 07:58 PM
