ds 650 head removal
Old Apr 30, 2004 | 01:06 AM
POLARISFREAK's Avatar
Default ds 650 head removal
Do you have to remove the engine from the ds 650 to get the head off, sure looks like you do? Thanks for any input.
Old Apr 30, 2004 | 01:12 AM
DuneMe's Avatar
Nope!
Take a look at my picture page. It really helps to grind away a bit of the upper motor mount hear the bottom and a little on the cross member support.
You will need a bar to push the head forward to get it past the cross-bar but, the head bolts will flex enough for you to get it by.
If you don't havea grinder or don't want to do it you can leave it connected at the rear mount and tilt the engine forward.
Old Apr 30, 2004 | 01:13 AM
Haulinonthedunes's Avatar
NO, You do not have to remove the engine to get the head off. Just take the front plastic off and gas tank and remove all hoses and wires and unbolt it and the head should slide right out. I put a new piston in mine and we did it with the motor still in the frame. [img]i/expressions/face-icon-small-smile.gif[/img]Lance
Old Apr 30, 2004 | 09:36 AM
SANDMAN430's Avatar
you don't have to but your only going to be like one bolt away from pulling the engine, i did mine two with the engine in the first time then i had to pull the engine to go to 720 think it was easier to take it out.
Divergent12
Dec 30, 2017 08:33 PM
toonces
Aug 5, 2015 05:55 PM
bpegram84
Jul 22, 2015 08:15 AM
bpegram84
Jul 22, 2015 08:12 AM
Desimation2k8
Jul 17, 2015 12:37 AM
