possible bad solenoid on warrior??
Old Apr 30, 2004 | 08:54 PM
XJ4ME's Avatar
Default possible bad solenoid on warrior??
my warrior wont start and all it does is click. I can pull start it and it is fine. I first thought it was the wire from the starter to the solenoid but i replaced it and it still just clicks. I also tested the battery and it is perfectly fine is it the solenoid??
Old Apr 30, 2004 | 09:20 PM
RoostItUp's Avatar
The only way to know is to go buy a new one. Have you tried cleaning your starter?
Old Apr 30, 2004 | 09:31 PM
RoostItUp's Avatar
My solenoid was bad and still turned over the engine, thats not the greatest way to prove it's bad. All that does is check to see if the fuse is burnt out in the solenoid not if it's actually wearing out.
Old Apr 30, 2004 | 10:25 PM
waynaferd's Avatar
This happened to me on my cousins Warrior. I thought it was my fault and had to spend almost $150 to get the starter rebuilt......My Bad!!!
Old May 1, 2004 | 10:55 AM
Bosch's Avatar
check your ground,,,,,,
Old Mar 6, 2005 | 04:30 PM
Carlbadmuva's Avatar
Jump the solenoid with a flat head screwdriver.. just touch the two studs with the screwdriver just like bartlettracing said....and if it starts ur solenoid is bad
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Jackg17
Sep 26, 2015 09:30 PM
Bernhard
Sep 25, 2015 12:45 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
