Severity of 01' raptor tranny problem
Old May 1, 2004 | 05:41 PM
GYTRaptor's Avatar
Default Severity of 01' raptor tranny problem
how severe is the tranny problem with the 01 raptors ??
Old May 2, 2004 | 12:08 AM
radfastdude7777777's Avatar
mine is good but my friends broke although he would rev it up and slam it into gear with his heal whenever he started it and is also a spazz and also let his 8 year old brother and his non experienced friends ride it (although his brother was good at it but couldnt hold on good)
Old May 2, 2004 | 12:50 AM
desracers's Avatar
As long the motor and pipe is plain stock, you wouldn't have any problem. Once you start upgrading to the motor like pipe and so on then you start to putting strain to the tranny.
That pretty much happen to every owner on Rappy once you start upgrading it.
The 02 model they upgrade the tranny by adding extra dog gear tooth and that pretty much take care of the tranny issue.
Old May 2, 2004 | 09:38 PM
raptorrider01's Avatar
how different is the 2002 raptor tranny compared to the 2001 tranny? length of gears?
Old May 2, 2004 | 09:41 PM
GYTRaptor's Avatar
Well hmmm.. all i have on mine is a slip on GYTR pipe and k&n, think that'll cause any problems eventually??
Old May 2, 2004 | 09:44 PM
DieScarred's Avatar
You might wanna watch out. You cant really tell. Theres guys out there that are pretty heavy built and still running strong on there 01 transmission.
Old May 2, 2004 | 09:45 PM
Choky's Avatar
LOL!
Old May 4, 2004 | 04:08 AM
maddog56's Avatar
I believe the 1st gear on the 01 was a little taller than the 02+ trannys.
Old May 4, 2004 | 05:25 AM
StockRappy01's Avatar
The 01 tranny will fail any time. Mine is dead stock 01, and bang!! Miss agear, hard land, whatever. Upgrade to 02. Sequential damage can be costly. Mine took out primary drive, primary driven, oil pump driven and a couple others. I reakon ratio changes are da bom.
Old May 4, 2004 | 05:27 AM
GYTRaptor's Avatar
What's the cost of the upgrade vs fixing it when it goes, and how long did it take to do or have done??
