Cough At About 2K
Old May 2, 2004 | 09:32 AM
pads's Avatar
Default Cough At About 2K
Slowly going up through the rpms while I am sitting in neutral reveals a cough about 2K rpm. I thought it was only with it cold, but it seems to do it when warm. I don't seem to notice it when I'm running. Is this have to do with the needle setting or the idle/air adjust circuit? I have the MBRP slip-on with the dyno jet kit. The needle setting is 2 down from the top, air screw is 2 1/2 turns out. The plug is a nice tannish color so it seems I have things close. What would you guys recommend? (other than getting rid of the MBRP)
Old May 2, 2004 | 12:52 PM
Eaglecollector's Avatar
I've not had this problem with my DS. But I did have he exact same problem with my 400ex and it was the neddle position. I ended up having to raise the needle 2 positions. Or lower the clip however ya want to say it.[img]i/expressions/face-icon-small-wink.gif[/img]
Old May 2, 2004 | 08:26 PM
pads's Avatar
So at about 2K that is the range for the needle not the idle circuit?
Old May 3, 2004 | 12:57 AM
hondabuster's Avatar
The circuit the carb is using, is related to the opening of the slide, and not rpm. Roughly the pilot circuit is for idle and a hair past, then the slide cut out takes over til 1/4 throttle. So depending on how far you opened the throttle, will determine which circuit. I would think youd hit 2000 on the pilot circuit, in neutral.
ReconBayou
Oct 31, 2022 05:37 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Mudfoot
Sep 21, 2003 01:17 AM
palebock
Sep 3, 2003 09:13 PM
Pumaguy
Mar 3, 2003 10:43 AM
