Push button kill switch.
Old May 3, 2004 | 10:58 AM
Shav0's Avatar
Default Push button kill switch.
My kill switch is the kind that you slide back and forth from "run" to "kill."
Does anyone know if a push button one, motocross style, can be used on a quad?
Old May 3, 2004 | 11:38 AM
warwgn's Avatar
yes as long as you have a cdi ignition, if you dont you will blow you fuse. the push button kill switch works by grounding your power out, so if you use it with a battery powered ignition (it's called tci I think) it will short out and blow your fuse. same with deadman kill switch or lanyard pull, you have to make sure you get the right style for your particular ignition
Old May 3, 2004 | 11:42 AM
Shav0's Avatar
Alright. Thanks.
My bike is CDI so it will work.
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Sep 9, 2015 09:38 AM
Elkaholic
Sep 6, 2015 02:44 PM
Jason An Stacy Jones
Utility ATVs
Sep 6, 2015 02:25 AM
toonces
Sep 5, 2015 01:14 PM
