REAR AXLE CLICKING ON 250T-BOSS
Old Jul 27, 2000 | 07:11 PM
BIGFOOT's Avatar
MY TRAILBOSS HAS DEVELOPED A CLICKING SOUND IN THE REAR DRIVE TRAIN.I HAVE INSTALLED NEW SPROCKETS AND O-RING CHAIN.IT DID IT WHILE THE CHAIN WAS OFF,SO I REPLACED THE AXLE BEARINGS WITH BETTER THAN STOCK.STILL DOES IT,BUT NOT AS MUCH.SEEMS TO "CLICK"ONLY WHEN THE BARS ARE TURNED LEFT OR RIGHT.I GETTIN' REAL ANGRY!ANYONE KNOW OF A FIX?BESIDES TRADING FOR A SHAFT DRIVE QUAD.
Old Jul 27, 2000 | 10:46 PM
Hermz's Avatar
mind does that, but only when i'm going in reverse. Are you sure your chain is tightened properly?
Oh yeah, you won't see me trading my chain in for a shaft
Old Jul 28, 2000 | 08:08 AM
Reckard's Avatar
I had the same problem with a Suzuki I owned years ago. It turned out to be the hub was loose on the axle splines. Unfortunately till I figured that out it had wore the splines down to the point that the axle and hub needed replaced. Polaris recommends that the splines be greased. I think this is a good idea and now check the hub bolt regularly. If your problem is like mine it will do it worse when turning sharply.
Randy
Old Jul 28, 2000 | 08:21 AM
BIGFOOT's Avatar
I DID CHECK THE HUBS AND THEY WERE TIGHT;BUT I WILL GREASE THEM TODAY AND SEE IF THAT HELPS. THANKS
Old Jul 28, 2000 | 02:03 PM
BIGFOOT's Avatar
WHO WOULD HAVE EVER THOUGHT!!! I GREASED THE SPLINES ON THE AXLE AND AFTER RIDING FOR ABOUT FIVE MINUTES,THE NOISE SEEMS TO HAVE GONE AWAY.I SURE HOPE THIS IS THE FIX!! THANKS ,RECKARD FOR THE HELP.
Old Jul 28, 2000 | 04:59 PM
ChopperBill's Avatar
See my post the clicking 500 axle. Brakes could be some of the problem.
Old Jul 29, 2000 | 12:06 AM
Hermz's Avatar
hehe, i know thats my problem... hehe, i don't have any splines left on teh left axle, just one big old weld
1986Vmax540
Jul 9, 2021 09:53 PM
STLyamwar
Jul 25, 2020 04:44 AM
bigred20653
Aug 31, 2015 12:41 PM
DeFox500
Aug 14, 2015 05:59 PM
Rider252
Jul 6, 2015 03:37 PM
