Recurring hub problem - 2000 500 Scrambler
Old May 7, 2004 | 04:26 PM
YT's Avatar
YT
Default Recurring hub problem - 2000 500 Scrambler
Hi everyone,
I have had my front right hub engaging at low speeds for not reason. Orginally I had drained, cleaned and replaced the hub fluid (did this in the winter). This seemed to solve the issue for the time being only to return shortly after. I changed the hub fluid about a week ago as the problem had come back, this again stopped the issue temporarly. I didn't notice any hub fluid on the rim either so I don't believe it is leaking. I have a service manual and intend to disassemble the hub tomorrow. What should I be looking for? What typically causes, this issue? (The hub engages randomly in 2x4 and 4x4 modes. Is this problem common to all polaris machines?
When I orginally experienced the problem I noticed that the fluid was gritty, and when I would rub a rag on the inside of the hub I noticed a rust colour (probably rust).
Hopefully I have provided everyone with enough information.
Thanks alot everyone, you have always given me great advice.
Jim.
Old May 7, 2004 | 05:15 PM
Polaridoo's Avatar
If all the components look good in there, then the spring that wraps around the rollers and the cam is probably too weak. So, I would replace that spring, if everything else looks good.
Old May 7, 2004 | 10:14 PM
BigBadScrambler's Avatar
Another item to look at is the armature plate. If it is bent even the slightest, it can cause the hub to engage/disengage. Also, make sure your hub nut is torqued properly
Old May 8, 2004 | 05:19 PM
YT's Avatar
YT
When I lifted up the atv and spun the wheel I could hear a click click sound. Have you experienced this before?
Thanks.
Old May 8, 2004 | 06:20 PM
YT's Avatar
YT
I removed the brake caliper and the clicking stopped. I noticed one of the brake shoes moving up slightly when the click would occure. I imagine adjusting the brake shoes would solve this problem. Let's hope it's the solution to my right wheel pulling.
Old May 10, 2004 | 07:02 PM
YT's Avatar
YT
I finally got a chance to take my hub apart. I am currently looking at the armature plate, it is black in colour except for 2 rings on the smooth side. The black was rubbed off in those two spots. Could this be part of my problem?
I can take pictures of components if you would like.
Thanks again.
Jim.
Old May 11, 2004 | 01:09 AM
That is normal wear. The tolerance for that plate is very little. If you are concerned, you may just want to get a new one anyway. They arent that expensive
Old May 11, 2004 | 08:59 PM
YT's Avatar
YT
Thanks BBS, Glad to hear it's normal wear [img]i/expressions/face-icon-small-smile.gif[/img]
Old May 12, 2004 | 12:46 AM
As long as it doesnt look like mine did in this thread
Chocobamofo
Jul 10, 2015 07:46 PM
coolguy420
Jul 10, 2015 01:17 AM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
Mikea1978
Jul 4, 2015 12:37 PM
