raptor carb problem
Old May 10, 2004 | 08:37 PM
duke9074's Avatar
Default raptor carb problem
my raptor wont idle and it seems to miss and stall out after aobut 10 seconds of running.any one got a clue is it my mixture or my jets how do i fix it?
Old May 10, 2004 | 08:42 PM
GYTRaptor's Avatar
I seem to be having a similar problem.. mine idles and runs fine at low rpm's but once you really throttle it, it spits and backfires and tries to die UNLESS I choke it slightly then runs a little better... Just about to look into it, but found that it is either something stuck in the carb (float bowl) or jetting... any ideas???
Old May 10, 2004 | 08:45 PM
duke9074's Avatar
no my warrior had the problem the choke makes it run better had to adjust the jets. my raptor will clear up if its reved its the low end thats bad any ideas?
Old May 10, 2004 | 08:52 PM
Rider1169's Avatar
check ur main jet, and clean out ur fuel filter, from all those years of sitting, it might have sediments of junk in there from the gas.
Old May 10, 2004 | 09:04 PM
duke9074's Avatar
how do i check my main jets and where is the fuel filter located?
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
kevbowe
Jun 1, 2015 01:17 AM
need4aquad
Feb 4, 2001 03:26 AM
RaptorGuy01
Oct 31, 2000 04:23 AM
