Lightweight Drag Slicks & Dyno Tires
I got rid of all my rear general purpose tires, only have paddles and pro wedges. I need to find a rear tire to use on the dyno. Lightweight is preferred as is low cost. Maybe an asphalt pattern is best in case I ever run 1/8 mile asphalt drags?
I'm running a banshee bolt pattern. If I found something used that was pre-mounted and cheap I might just go that route.
Scooby, I don't know if my PM went through (I am having computer troubles). The tires I have weigh 18lbs 4ozs on a 10x10 .125 Douglass. They didn't feel that heavy, but saying that sounds heavy.[img]i/expressions/face-icon-small-confused.gif[/img]
Also Mickey Thompson makes some true slicks for Jr. Drgasters that would hook up great for you and work nice on the strip, but they are on the expensive side. I think I found them for $100 a peice. 19.5x10x10, they would probably be the lightest most grip tire available...that I know of. I think Jegs carries them.
Jegs
If not try jr.drags.
I think you are going to get tire growth on any light weight, high traction tire. I don't know how it would affect the dyno.
Jegs
Yeah I got the PM, thanks. The Duro distributor doesn't show any dealers in my area so I'd have to use online ordering. 18lbs is a little high but it costs you a lot less $$$. Still deciding what tires to buy.
