Lightweight Drag Slicks & Dyno Tires
Old May 14, 2004 | 12:40 PM
ScoobyDFW's Avatar
Default Lightweight Drag Slicks & Dyno Tires
I got rid of all my rear general purpose tires, only have paddles and pro wedges. I need to find a rear tire to use on the dyno. Lightweight is preferred as is low cost. Maybe an asphalt pattern is best in case I ever run 1/8 mile asphalt drags?
I'm running a banshee bolt pattern. If I found something used that was pre-mounted and cheap I might just go that route.
Old May 14, 2004 | 02:49 PM
ScoobyDFW's Avatar
how do you think some of these lawn tractor tires would work on dyno?
22x11x8
20x10x10
20x10x8
25x12x9
or a flattrack tire like dunlop kt24 20x10x10 dunlop kt24 20x10x10
Old May 14, 2004 | 04:22 PM
SHOTGUN's Avatar
25x12x10 dunlap is the lightest tire I know of. Comes stock on p650, no good for anything else, I'll trade you them for anything as equally worthless.
Old May 17, 2004 | 12:18 PM
ScoobyDFW's Avatar
25" is probably too tall for what I'm looking for.
does tire growth of a drag slick mess up dyno readings??
Old May 17, 2004 | 05:05 PM
Ward660R's Avatar
Scooby, I don't know if my PM went through (I am having computer troubles). The tires I have weigh 18lbs 4ozs on a 10x10 .125 Douglass. They didn't feel that heavy, but saying that sounds heavy.[img]i/expressions/face-icon-small-confused.gif[/img]
Also Mickey Thompson makes some true slicks for Jr. Drgasters that would hook up great for you and work nice on the strip, but they are on the expensive side. I think I found them for $100 a peice. 19.5x10x10, they would probably be the lightest most grip tire available...that I know of. I think Jegs carries them.
Jegs
If not try jr.drags.
I think you are going to get tire growth on any light weight, high traction tire. I don't know how it would affect the dyno.
Old May 17, 2004 | 11:42 PM
ScoobyDFW's Avatar
Yeah I got the PM, thanks. The Duro distributor doesn't show any dealers in my area so I'd have to use online ordering. 18lbs is a little high but it costs you a lot less $$$. Still deciding what tires to buy.
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
highwayman
Sep 19, 2015 12:59 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
