should I make my 400 a 440?
Old May 14, 2004 | 04:39 PM
needa440ex's Avatar
Default should I make my 400 a 440?
Does this 440 help my bike? Will i be able to keep up with a raptor? How bad can I spank other bikes ? New to this forum .....
I ride in glamis about 20 times a year >.......
Old May 14, 2004 | 08:25 PM
00400ex's Avatar
get ready for alot of work
Old May 15, 2004 | 12:09 AM
Ernie660R's Avatar
I just recently built a 416EX, 11:1 piston, Stage One Hot Cams, I polished and Ported the Head and it ran the 1/8th ET @ 68 mph. He was beating Piped and Jetted Raptors and some Banshees.
Now this is with the stock head pipe with a aftermarket slip on only, stock carb, 48 pilot, 165 main. There is still a lot to gain with other tuning methods.
If I were you just go with the 416 set up.
Old May 15, 2004 | 10:54 AM
400sEXridr's Avatar
what did you use to make yours a 416
Old May 15, 2004 | 11:07 AM
Pladeaux's Avatar
My Pal is Considering a 440 kit,Cam, Porting, etc. He is hesitating right now, weighing in the fact that more HEAT is generated and out here in Sunny So Cal, overheating can be a problem. Not to discourage You, but to see all angles.
Plad
Old May 15, 2004 | 09:01 PM
Ernie660R's Avatar
If I am not mistaken it is a 2mm over stock bore. I really can't remember but I think. Any way find a good machine shop that will do the over bore and thats it, no sleeve has to be installed.
Old May 17, 2004 | 12:12 AM
needa440ex's Avatar
what kind of cam should i install??? JE piston is what they usee..........................
Will the 440 give me problems ?????????????????????? als o...... should i get a rev kit????????
user493
Aug 13, 2015 12:54 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
toonces
Jul 31, 2015 09:27 AM
Nazz26
Jul 30, 2015 11:51 AM
cSchwartz
Jul 12, 2015 07:42 PM
