HUB OIL 2004 400 SPORTSMAN
You can fill it then turn it to the 4:00 position and let the excess drain. Or, like I do, turn it to the 4:00 position and use a syringe to inject the fluid in there. Or if you are using the Polaris hub fluid, the bottle should have a long neck on it which will make it easy to put in at that position
bradco
Aug 21, 2015 08:11 PM
