HUB OIL 2004 400 SPORTSMAN
Old May 17, 2004 | 04:07 PM
KINGSCLEAR's Avatar
Default HUB OIL 2004 400 SPORTSMAN
Changing my hub oil for the first time. what is the proper fill procedure. How do I know it is full
Old May 17, 2004 | 04:09 PM
BigBadScrambler's Avatar
Fill it at a 4:00 position. It doesnt take much. Once it starts dripping out at the 4:00 position, you are full.
Old May 17, 2004 | 04:11 PM
KINGSCLEAR's Avatar
I'm not sure I understand. I fill and then turn it to the 4 oclock position?How can I fill at 4
Old May 17, 2004 | 04:14 PM
You can fill it then turn it to the 4:00 position and let the excess drain. Or, like I do, turn it to the 4:00 position and use a syringe to inject the fluid in there. Or if you are using the Polaris hub fluid, the bottle should have a long neck on it which will make it easy to put in at that position
Old May 17, 2004 | 04:17 PM
KINGSCLEAR's Avatar
Gotcha thanks .I'm using the Polaris oil but no long neck or tube. I'll fill and turn wheel. I have 680 miles and it's never been changed it is time
Old May 17, 2004 | 04:34 PM
LOL. Yep. Time to change it. Each hub only holds a few ounces, so dont be worried if very little comes out.
COFatboy
May 2, 2020 12:06 AM
velcro7279
Aug 24, 2015 01:15 PM
bradco
Aug 21, 2015 08:11 PM
Stirling
Aug 11, 2015 07:23 AM
Gtsordo
Jul 13, 2015 10:38 PM
