2001 Scrambler 500 4x4
Old May 19, 2004 | 02:23 AM
rdg72's Avatar
Default 2001 Scrambler 500 4x4
I've heard that 400 Scramblers are quicker, so I was just wandering about how fast a 500 could do? Also any specs and info you guys can give me on a 2001 Scrammy 500 4x4 would be greatly appreciated. Thanks alot and I'm pretty sure I can trust you guys, I've had some other posts and looked at others and you all give some really good info.
Old May 19, 2004 | 02:34 AM
Sidewinder500's Avatar
the 500 will do about 65 to 67 not sure if the 4x4 is any slower though.
What kind of specs and info are you looking for?
Old May 19, 2004 | 02:36 AM
rdg72's Avatar
Some specs like gas mileage, and weight. Info if these have lots of problems and if so what kind.
Old May 19, 2004 | 03:57 AM
BigBadScrambler's Avatar
I can get anywhere from 60-80 miles on a tank, depending on how Im riding. It weighs roughly 540lbs dry weight. The only major problem that I have encountered besides the usual wear and tear items and the problems that were my fault, is a bad CV joint. Not a big deal though. These are tough go anywhere machines. The perfect blend of sport and utility. Anything else you want to know?
Old May 19, 2004 | 04:02 AM
I have had trouble with my rear brake but a replaced bleeder and re-bleeding the brake lines took care of that problem.
And have had to tighten my chain a couple times.
Old May 20, 2004 | 01:54 AM
crpadiem1's Avatar
I am waiting for a bleeder to come in for mine too, in fact I have 2 on order as one will not stop bleeding no matter how tight you make it and the other will not bleed at all, I have to open it up enough to let the air escape past the threads. I have only had mine 2 weeks but I love it, have always had atvs but they were mostly utility and this one really is a blast, quick, powerful, gets out of bad spots better than the sport racers too, plus no shifting either.
Old May 20, 2004 | 09:08 AM
Redbullssg's Avatar
I have a 400 4x4. The 500 will be much more reliable for you. It will last much longer before you need to rebuild it also. The 500 is a bit more expesive to modify and you won't get the horsepower of the 400 with mods, but make up for most or that in torque. The 500 will of coarse be a bit more complicated than the 2 stroke when it comes to a rebuild. Better gas milage comes with the 500, or generally speaking with a 4 stroke compared to a 2. Speed of the 500 4x4 I a guessing is a bit higher on the topend than a 400, not sure. I would guess it would be around 68mph, but getting there, the 400 pulls a bit harder and quicker. The 500 will have much more power in the low end, as where a 400 needs to be clutched to engage at a higher rpm to get into its powerband. Between the two, they have there pluses and minuses, so I guess it is all up to what you will be using it for and what you want out of it...
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
exmotocrosser
Sep 13, 2019 06:12 AM
35dodge
Sep 29, 2015 09:40 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
