Installing a pro-design cool head on a 88 250r, Jetting? Which Dome?
Old May 20, 2004 | 05:01 PM
punkXcasanova's Avatar
Default Installing a pro-design cool head on a 88 250r, Jetting? Which Dome?
I want to get a little extra pep out of my bike so i went and purchased a pro design cool head with a 22 cc dome. I have no porting or any work done on my engine what so ever. I have a paul turner pipe, delta v-force reeds, K&N Air cleaner, and ive done some jetting. The stock main jet was a 158 i think and i moved to a 160 main after installing the pipe and reeds and filter. It seems to run pretty well with the set up i have right now but id like to get a little more out of it as i mentioned. My questions are first of all, is the 22 cc dome the right choice for my set up? I went with this dome thinking since my motor is stock and i shouldnt raise the compression too much. Can i go with a smaller dome or is the 22 the right choice for now? Also has anyone been down this road before and knows what jetting size works good with this setup? I havent installed anything yet cause i wanted to bounce this off a few people first. I havent even opened the dome package and im not going to until i know its the right one for me. Thanks in advance to anyone who comments on this.
Old May 20, 2004 | 06:28 PM
bansheeesmoker's Avatar
I dont know what the stock compression is but I dont think you will have to rejet. keep it on pump gas. try it and plug chect it.
Old May 21, 2004 | 11:02 AM
trx250Rob's Avatar
Bansheesmoker is right, keep it on pump gas. If you go too high on the compression you will need to run race fuel to prevent detonation. I tried it and I feel it was just too expensive and hard to acquire to justify the results.
22 cc should be about right for your build. If you are looking for some real kick I would get the cylinder ported. You looking at about $300 but what a difference it will make.
Old May 21, 2004 | 01:07 PM
Yeah thats what im looking to do but this motor has such low hours i didnt wanna go porting it right away. Thanks guys.
bpegram84
Jul 22, 2015 08:15 AM
bpegram84
Jul 22, 2015 08:12 AM
Aitch
Jul 21, 2015 09:40 PM
CRamshaw777
Jul 18, 2015 05:46 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
