Sprocket bolt keeps coming loose
Old May 21, 2004 | 12:29 AM
HughJazz's Avatar
Default Sprocket bolt keeps coming loose
I have a 86 250R and the bolt the hold the frt sprocket on keeps coming loose. I will ride it for about 30 min and check it and it is starting to come out. I have lock tighted it in and that doesn't help. the thead are good I can get it good and tight, any ideas
Old May 21, 2004 | 02:19 AM
CroBiker's Avatar
better locktight, designed to handle high heat jus in case, a lock washer wouldn't hurt, and jus torque it down tighter. this always works for me in whatever i'm doing. also, clean out the threads on the bolt, and nut before you apply more locktight. if the metal rubs u can get a graphite-like powder and shavings, and it won't let the bold hold tight.
Old May 21, 2004 | 01:36 PM
trx250Rob's Avatar
The locktight should do it. I was having trouble with the rear sprocket and brake rotor bolts coming loose. I put a dab of locktight on the exposed thread and it has held.
Old May 21, 2004 | 02:03 PM
HA2's Avatar
HA2
locktite. i dont remember if there is a lock washer or not but if there is it should be replaced. you shouldnt have to tighten extremely hard, you an break the bolt very easily....trust me.
Old May 21, 2004 | 02:05 PM
HA2's Avatar
HA2
btw i dont use locktite on this bolt because i fear it will break off and ill never get it back without drilling. ive never had a problem. when you're tightening the bolt, how do u keep the sproket still? with the compression of the motor?
Old May 21, 2004 | 02:08 PM
trx250Rob's Avatar
You could have a worn out bolt, if the thread are worn this will cause it to loosen up.
95wolv
Jul 17, 2015 08:13 PM
skeets44
Jul 17, 2015 01:04 PM
Desimation2k8
Jul 17, 2015 12:37 AM
Unzzy66
Jul 11, 2015 10:01 PM
