banshee carb jetting
Old May 21, 2004 | 05:14 AM
DocDon01's Avatar
Default banshee carb jetting
i was looking for some help trying to buy the right jets for a 98 banshee with stock carbs. with a 60 over bore cylinders. there are 280 mains and i think 25 pilots. it seems to be lagging top and bottom. i pulled the plugs out and notice it was burning rich. the plugs were driping wet. just trying to avoid doing the famous buy three up and three down and compare and contrast. thanks don
Old May 21, 2004 | 09:38 AM
sAyIt_fmf's Avatar
Keep the main as you have them...try a 30 pilot...needle on the 3rd clip....about 1 2/3 -2 turns on the air screw. Keep the airbox lid on. Remove just the snorkle.
I did not notice if you have pipes...the above jetting guidline is for a piped quad.
Old May 21, 2004 | 10:02 AM
nickxc's Avatar
go here and read this is all you should ever wanna know about jetting a banshee it is sponsered by benbb at bansheehq.com check it out!!
http://www.dfn.com/benkaren/jetfaq.html
Old May 21, 2004 | 12:20 PM
Hiram's Avatar
Your rich, make sure the air filter is clean.
Old May 21, 2004 | 12:36 PM
nickxc's Avatar
Its impossible to tell if you are rich or lein without knowing your altitude, air temp., air screw setting, needle clip position and all the other variables. if your plugs are wet then you are obviously rich but you dont know where the richness is comming from It could be your main, needle clip, or pilot position. a lein condition in one area could be masked by a rich condition in another...
Old May 22, 2004 | 09:07 PM
DocDon01's Avatar
the pipes are after market, the air box was removed and replace with individual foam filters.. thanks for the help
Cole Hadden
Jun 15, 2025 09:05 AM
bpegram84
Jul 22, 2015 08:15 AM
bpegram84
Jul 22, 2015 08:12 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
