Edelbrock Carb metering dial
Old May 21, 2004 | 10:38 PM
fizzak's Avatar
Default Edelbrock Carb metering dial
Is it supposed to fit under the tank? Mine does not fit and I had to put the standard bolt back in.
Old May 21, 2004 | 11:29 PM
fizzak's Avatar
Nevermind, I read that its a tight fit and it's not supposed to stay in there exept for tuning with the front plastic off.
Old May 22, 2004 | 12:00 AM
RaptorRacer1's Avatar
You can buy a 1/2" spacer at the hardware store, or use a stack of washers under the rear bolt on the gas tank. Then you can leave the metering rod adjuster in there. All the plastics will still fit. That is what I have done on mine.
RR1
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
