bleeding the coolant system
Old May 22, 2004 | 03:42 PM
thewayout420's Avatar
Default bleeding the coolant system
can anyone help me out?i need to know how to bleed the system on my scrammy.thanks
Old May 22, 2004 | 04:58 PM
RAJ's Avatar
RAJ
They should be a bolt on top of the head....what I did was took it out and then added my Engine Ice until it came out the hole.
Old May 22, 2004 | 05:52 PM
i heard something about marking the bolt before its removed?
Old May 22, 2004 | 06:57 PM
mudmaster250's Avatar
thats probly so u dont over tighten it
Old May 22, 2004 | 07:02 PM
scrambler123's Avatar
Thewayout420 could you feel a difference after installing the reeds?
Old May 22, 2004 | 07:13 PM
DGScrambler400's Avatar
i could feel a gain on bottom end, nothing huge, but worth the money IMO. i had a little more wheel lift(LOL) after the reeds..
Old May 22, 2004 | 07:30 PM
i installed a pipe,filter and reeds all at the same time,so i couldnt really tell you the difference..
Old May 23, 2004 | 02:52 PM
should i be using a new head gasket or rtv sealer when putting it back together?the gasket looks to be ok..
Old May 23, 2004 | 04:05 PM
RAJ's Avatar
RAJ
Every time I took my head off I put on a new head gasket. They all looked ok but I did not want to tear it back down again if it would leak. I would put a new one on if I was you....just to be safe.
Old May 23, 2004 | 04:08 PM
modquad's Avatar
Intalling new gaskets is always cheap insurance. Couple of bucks spent=many headaches saved. [img]i/expressions/face-icon-small-smile.gif[/img] Don't forget to retorque the cylinder base bolts after the engines first good warm-up....that's if you had the cylinder off.
