air pressures
Old Jul 31, 2000 | 11:21 PM
Brushdog's Avatar
The decal on my 2000 Mag 500 says 3 psi in front and 4 psi in the back.I have changed it to 4 psi in the front and 5 in the rear.Have any of you played with different pressures and why do you have them set higher or lower?
Old Jul 31, 2000 | 11:30 PM
REDYAM's Avatar
The lower you go the more tracktion youll get but you dont want to break a bead on turns or jumps or tire fold
Old Aug 1, 2000 | 09:08 AM
MagnumMudMan's Avatar
On a big utility quad, set the fronts up around 5 to 6 pounds and it will steer a little eaisier. Higher pressures generally will get you a little more speed and will turn easier. Lower pressure generally will give you more traction and a better ride. Play will it a little and see where you like it. Oh, I think your sticker says 4 in the front and 3 in the rear. You might want to double check this.
Old Aug 1, 2000 | 08:24 PM
Pfelect's Avatar
On my stock Dunlops I settled on 5psi front,4psi rear.
Old Aug 1, 2000 | 08:31 PM
Brushdog's Avatar
Your right MagnumMudMan,I had it backwards.Thanks
bmxatv10
Oct 14, 2022 06:23 PM
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
2many2ride
Sep 27, 2015 04:35 AM
MPDano
1) Engine problems..
Sep 20, 2015 09:48 PM
Hw00d
Sep 10, 2015 08:53 AM
