400 Jetting with HPD pipe & clutch Kit
I have just fitted a HPD pipe and clutch kit (don't talk to me about the poor fit of the pipe), and have a K&N filter, but am having trouble jetting it correctly. I have kept the 35 Pilot Jet, changed to a 260 main jet, and the badly photocopied instructions that came with the pipe say to use a 6CEY6 needle in the middle position. I have asked at local dealers, and asked the local agent of the Mikuni carbs for this neelde, but that have never heard of it. The stock one is a 6F9, and I am having trouble getting the jetting just right. Usual story, good down low, to rich down low, to lean up top. I tried a 30 Pilot Jet, to clean up low RPM, but still not right.
Any help would be great. The rush of the 400 when it gets on the pipe, but i fear that as it is running lean, the rush might not last!
TheJoka
400 Scram
TheJoka
400 Scram
what year quad...what altitude are you riding....what temp range.....
you might want a new polaris dealer because the 6CEY6(POLARIS # 3130476) is the stock needle on newer sport 400's and scrambler 400's I think 98 and up,if I remember the 97 400's used a 6CE6.
What was the problem with the fit of your pipe I have installed 3 HPD pipes and all of them fit like a glove and ran flawless
By the way on my 99 sport when I just had a stock eng. w/pipe and clutch kit I was running a 250 mainjet a 30 pilotjet and 6CEY6 on the #3 clip position, at 2000 feet alt. and 95deg+ temps and it ran great
[RED]CHECK OUT THE HI-PERF POLARIS PAGE[RED]
http://msnhomepages.talkcity.com/RightWay/hiperfpolaris
99 sport 400
hpd pipe
hpd muffler
hpd porting
hpd billet head
hpd girdle kit
39mm kehin pwk carb
renthal cr low bend bars
wiseco piston
hpd aggresive clutch kit
v-force reeds
k&n filter
2000 scrambler 400 2x4
prm alum. a-arm gaurds
dg alum. bumper
k&n filter
99 sport 400
hpd pipe
hpd muffler
hpd porting
hpd billet head
hpd girdle kit
39mm kehin pwk carb
wiseco piston
v-force reeds
k&n filter
dg alum. bumper
k&n filter
The HPD pipe I bought fit great, with no problems at all. I had to deburr the bolt holes on the exhaust pipe to cylinder adapter, but that took about 30 seconds with a rat tail file.
I'm running a 250 main, the needle 1 notch lean from center, and a 30 pilot jet. The plug is still black, running 80 to 90 deg. F, at near sea level.
hey jack what bogus info are you talking about,I know all the specs I gave are right.
All the specs the capt. gave look good.
The only bogus one in here may be thejoka
99 sport 400
hpd pipe
hpd muffler
hpd porting
hpd billet head
hpd girdle kit
39mm kehin pwk carb
wiseco piston
v-force reeds
k&n filter
dg alum. bumper
k&n filter
99 sport 400
hpd pipe
hpd muffler
hpd porting
hpd billet head
hpd girdle kit
39mm kehin pwk carb
wiseco piston
v-force reeds
k&n filter
dg alum. bumper
k&n filter
Azelmo
Most of my running is at sea level, temp at about 15-20 deg C (metric temp).
The pipe I got for my 96 400 was a poor fit. I had to file out the holes for the head adpator, modify the springs that hold it on, modify the mount for the little rubber stopper that rests against the top frame rail, and it still rests on the gear selector stick. Poor fit in my book.
TheJoka
400Scram
TheJoka
400Scram
Well I have got one.
I had to have the needle flown in from Australia.
I will let you know how I get on, but I will probally have to redo it soon when I get my GP Cool Head.
Also I have just had some custom tie rods made with decent rod ends. The rod ends will last a lot longer, and then only cost $9.00 to replace.
TheJoka
400Scram
TheJoka
400Scram
