Greasing the Swing Arm...
Old May 22, 2004 | 10:10 PM
spike99's Avatar
Default Greasing the Swing Arm...
For those of you who are tired of taking apart your unit's Swing Arm for greasing, you can install a grease fitting into it (if one doesn't already exist). I just finished the installation of a grease fitting into our Pred-90's Swing Arm.
Here's the steps I used:
a - Purchase 3/16" straight direction Drive-In type Grease Fitting.
b - Take 5/32" drill bit and mark its needed depth with tape on the bit.
c - Put the mini on a high "belly mount" stand and ensure it's secure.
d - Crawl under the mini. (You'll need a good back for this).
e - Drill upwards into the Swing Arm Bar - to the depth of the tape.
f - Using a proper size socket and an 8" extension, hammer in the grease nipple.
g - Apply grease until it comes out one of the Swing Arm busing ends.
* It took me 90 squirts before grease came out one of its end bushings.
For a visual, surf:
- Press Here 1 -
- Press Here 2 -
- Press Here 3 -
At our Pred-90's next 6 month greasing, I only need to grease its installed grease nipple with 3 or 4 squirts.
Hope this idea helps reduce your future Swing Arm greasing maintenance time.... .
fd24
Jan 16, 2019 08:59 AM
bigred20653
Sep 19, 2015 02:11 PM
bmark0610
Sep 7, 2015 09:42 PM
rawbdiggity
Sep 7, 2015 12:05 PM
Bell21
Jul 28, 2015 06:52 AM
