lift kit.
Old May 23, 2004 | 10:36 PM
CatsRule's Avatar
Default lift kit.
Im thinking of making my own lift kit. I looked at my buddies and its basically 2 pieces of metal and 2 bolts for each shock. I was gonna trace his and cut them out of some think metal. Do you think this will work or am i wasting my time. I was hoping for 1.5" to 2" lift.
Old May 24, 2004 | 01:12 AM
Bear4570's Avatar
Default lift kit.
CatsRule; I don't see why it won't work. However IMHO use a hard enough metal and high strength bolts or you could have a problem. I put Moose's kit on mine as nobody had done it yet that I know around here. Works fine except that the bike is a little more tippy in high speed turns and watch the leaning on hill sides and trails. I almost rolled mine a week or so ago, having to learn some new skills.
Old May 24, 2004 | 08:31 PM
CatsRule's Avatar
Default lift kit.
I think ill wait until the summer and make them. I got a summer job in a machine shop so ill machine them there and they have a powder coat painter there to so i can powder coat them too.
Old May 26, 2004 | 01:57 AM
weez440's Avatar
Default lift kit.
it should work no problem catsrule but you also gotta ask yourself do you need to put a lift kit in it? cause if you are looking at just raising it up so you can go through more water or for ground clearance then you would probably be better off buying a 400 or something cause like bear said it will make it tipier and well it does take alot of getting used to but the lift kit does appear to be a simple design and for that kind of money hell fabricate them yourself
QuadRiders
Oct 22, 2015 04:13 PM
Alex G.
Sep 16, 2015 12:13 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Cantbuytime
Aug 17, 2015 06:33 PM
Cantbuytime
Aug 16, 2015 09:13 PM
