quick jetting?
Old May 25, 2004 | 06:45 PM
MrBigIron's Avatar
Default quick jetting?
Can any one tell me where I should be at for jetting and clip height ? I am running a rwr stage 1 with a accle pump and ported intake. I am at about 1000 above sea leavle and will be running at about 75 degrees.
Old May 25, 2004 | 06:53 PM
SANDMAN430's Avatar
they send that tm 45 with a 150 main jet but i think you might want to be at about 145, but we would also need to know if you are running a air tube to the airbox ot carb mount that is needed info to really help.
Old May 25, 2004 | 06:57 PM
MrBigIron's Avatar
OOOOOOOOO yha !!! I forgot about that. I am running with the air tube and box but no lid[img]i/expressions/face-icon-small-smile.gif[/img]
Old May 25, 2004 | 07:04 PM
SANDMAN430's Avatar
i'd try in the 145 range, that is where i was running with carb mount, went to the tube and i'm up to 160 but that is with the 720 version.
Old May 25, 2004 | 09:08 PM
MrBigIron's Avatar
any sugestions on needle height[img]i/expressions/face-icon-small-smile.gif[/img]
Old May 26, 2004 | 11:29 PM
MrBigIron's Avatar
bump!
Old May 27, 2004 | 08:15 AM
sam's Avatar
sam
Im on the middle possition if I recall right. Ill need to double check. where are you at for pilot? im at 32.5 and I can still turn the air screw out and out with no change in idle. so Im at 2.5 turns. the pump needle is turned slightly to the right. right at the intake.
do a search on tm45 and pm hightower you will get tuns of info.
Sam OUT[img]i/expressions/face-icon-small-tongue.gif[/img]
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Rooky
Sep 9, 2015 03:16 AM
