Motion Pro Thumb Throttle Conversion
Old Aug 1, 2000 | 07:37 PM
BansheeBill's Avatar
I am considering getting rid of the TORS on my Banshee and replacing it with a Motion Pro system. I would like to get some opinions from those of you who have already switched. Is it worth the effort?
Old Aug 1, 2000 | 08:26 PM
asnowmobiler's Avatar
I have one on Mine, only on the tightest trails it can be tricky. If you get one, make sure you get the idle kit, without it your idle is adjusted at the throttle. It sometimes raises the idle when you turn the bars. You have to carefull how you route the cable. GOOD LUCK!
Old Aug 2, 2000 | 09:50 AM
Bruce's Avatar
I have the motion pro kit that allows you to keep the thumb throttle. You will need the idle kit too. It's a bit scary drilling holes in your carbs, but study and follow the instructions and it will be fine. Mine turned out great. I think toomy's site has some instructions online about the tors removal and idle kit.
Bruce
2000 MotoFast Banshee
99 Suzuki dr350
Old Aug 2, 2000 | 10:21 AM
sAyIt_fmf's Avatar
I really liked the motion pro system with the stock thumb throttle ....
I did not like the twist grip...maybe it's just me...But it seems like the twist grip is great in the wide open areas like a desert...But touchy in the woods....
Maybe I just did not give it a chance.
Old Aug 6, 2000 | 01:23 AM
azrob's Avatar
I found that the twist is great for long stretches, but I prefer the thumb for short bursts, as you're likely to do with the Banshee.
2quiker
Mar 22, 2022 08:36 PM
MeadowlarkFarm
Nov 27, 2019 08:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
black_thunder
Sep 6, 2015 04:41 PM
