Sport Quads Discussions on sport quads.
Cams: Hi lift vs long duration...
Old May 26, 2004 | 09:07 PM
dragracer789's Avatar
Default Cams: Hi lift vs long duration...
Can sombody explain to me what the power diffrence is between Hi lift, long duration, and hi lift AND long duration cams? Which type of cam makes the biggest diffrence? Thanks alot...
Old May 27, 2004 | 12:11 PM
AlkyBurninX's Avatar
Your duration (more than anything else) affects the rpms that the power comes on. Longer duration, high the rpms. Lift really needs to be matched to the flow of the head. Just because you lift a valve farther, doesn't mean the head is flowing more. So, basically the way I see it is find the lift that matches your head flow. Then run a short duration cam for torque, long duration for high rpm HP. There are a lot of other factors including ramp speed, centerline, lobe seperation, etc that also need to be taken into consideration. Luckily you don't really have that many choices in ATV cams.
ReconBayou
Oct 31, 2022 05:37 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
IMLN
Sep 28, 2015 03:32 PM
2many2ride
Sep 27, 2015 04:35 AM
wrencher82
Sep 24, 2015 03:39 PM
