NEED HELP ASAP Leaving in 12hrs!!!
Old May 28, 2004 | 12:14 AM
MudStud's Avatar
Default NEED HELP ASAP Leaving in 12hrs!!!
Ok this is messed up. The DS sat outside for a week and not its battery is dead dead dead. It did get rained on but big deal. here is what is messed up. It wont rev past idle. It just pukes and sputters. I cleaned the carb & warmed it up.. Nada.. put the original rectifire on as I was dumb enough to buy the performance crapy one.. It wont hold a charge its just flat dead..
NOW, here is what kicks me.. When the head lights are on it runs fine!!! no sputters. I can hold it at 3grand and turn the lights off and it goes to heck turn them back on and it runs good.. WTF WTF???
Help a bro out...
Old May 28, 2004 | 12:17 AM
ANNIHILATER's Avatar
No Mercy Racing! Got NOS?
Ive had the same prob, and it was a ground issue. Check and re-tighten your grounds from battery to frame.
Old May 28, 2004 | 12:19 AM
MudStud's Avatar
I took the bat off to charge it.. I did have it off put it back on then it died.. I bet it got crud in there. I will do that.. I hope that is it!!!!
Old May 28, 2004 | 12:49 AM
MudStud's Avatar
Hurley WI. its a 5hr drive [img]i/expressions/face-icon-small-sad.gif[/img] going for a 3day ride..
Old May 28, 2004 | 01:50 PM
biggerisbetter's Avatar
My origional rectifier acted the exact same way. It would OVER charge the system and the CDI would cut out. If you leave your head lighs on you will be ok, but you will eventually have to buy another rectifier.
bigger.
Old May 28, 2004 | 07:37 PM
Air's Avatar
Air
A battery that is shorted internally will act the same way.
Old May 31, 2004 | 12:00 AM
MudStud's Avatar
Well I called my buddy MRHP [img]i/expressions/face-icon-small-smile.gif[/img] and spoke with him early friday morning and gave him the low down. He said get a battery and its fixed. So I go out and spend 80 bucks for a quick battery and viola! it works.. I had no issues this weekend with the motor. Now the bearings on the other had did go out and out they went. My axle is wobbling in the carrier [img]i/expressions/face-icon-small-sad.gif[/img] but at least it starts [img]i/expressions/face-icon-small-smile.gif[/img]
Old May 31, 2004 | 12:32 AM
Hightower's Avatar
just because the axle wobbles doesn't mean the bearings are bad. the axle nut may just be loose. you need to check for axle play frequently, while you still got her propped up servicing the chain kill two birds with one stone. if there is play, retighten the axle nut accordingly. riding with a loose nut is what kills the bearings, there still may time to save them and its a 2 minute job to tighten the nut.
many people have needlessly replaced perfectly good bearings not understanding the concept of tapered bearings like the DS has.
slowgsxr97
Sep 8, 2015 07:33 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
400H0
10
Aug 20, 2015 07:34 PM
Hatrackr
1) Engine problems..
Aug 11, 2015 09:03 PM
