KEBC Dead - BIG Ride This Weekend - Need HELP!
Old May 28, 2004 | 01:23 PM
BigMtnRider's Avatar
Default KEBC Dead - BIG Ride This Weekend - Need HELP!
Hola all! I posted this problem about a week ago, and still no help. My KEBC is DEAD, and I've got a BIG ride this weekend! I had a dumb@ss mechanic work on my '03 P650 when I totalled it, and he cut the wires leading to the black 4-pin connector underneath my shifter assembly. I'm not an electrical genius, so I thought I'd ask you guys. Does the black 4-pin connector lead to the KEBC actuator or something? Where exactly is the KEBC actuator, and how can I tell if it's bad? Where is the 2WD/4WD actuator, and how can I tell if it's bad? My 4WD seems to be working ok (for now), but I definitely have the 2WD/4WD flashing problem. In fact, when I switch it into 2WD, it seems like it remains in 4WD (I can't tell by the console because it's flashing back and forth!). My fuses are working fine -- we switched fuse boxes with my friend's P650, and the KEBC worked perfectly. We jumped my KEBC off the battery to reset the motor, and the motor also worked perfectly. Am I missing something here? I don't want to get into the deep woods this weekend and have something go seriously wrong...
Old May 29, 2004 | 05:55 AM
Customfabandweld's Avatar
I had the same problem (about no one posting a reply) when I was having problems with the KEBC. Mine works periodically. There are some recent posts about disconnecting it entirely.
Old May 29, 2004 | 08:57 AM
KVF700's Avatar
I heard someone say they took the fuse out ,so they could get a few more miles per hour.Maybe if you take yours out you'll get your ride in this weekend with no trouble.
Old May 29, 2004 | 01:52 PM
PrairieDust's Avatar
I had the 2wd/4wd flashing light problem before. The fix in my case was to remove the KEBC motor/actuator from the belt cover and apply grease to the actuator shaft where it goes through the belt cover.
Approx 1000 km problem free kms since doing this.
Old May 29, 2004 | 07:48 PM
meany's Avatar
from what i can tell from what you are saying is if you put a new fuse box in it works fine. so i would say it is the fuse box giving you the problem . if i remember right there was a post about the fuses not fitting right . said too bend tabs lightly at fuse box to make tighter fit then aply electric greese to fuse and box tokeep out water my 2 cents
skinnyr6
Aug 25, 2023 02:18 AM
Frisky2050
Apr 9, 2020 11:19 AM
rcappie4
Jul 10, 2015 04:54 PM
yambam13
Jul 4, 2015 01:49 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
