Better Plow Frame Mount
Old Aug 2, 2000 | 11:36 AM
Arrowhead's Avatar
Is there a better way to mount a plow on a Sportsman? The factory mounting bracket is good, but it hangs down about three inches so you loose a lot of ground clearance. I'm going to use the winch for raising a lowering, so it don't need the rest of the brackets mounted anyway. I was wondering if anyone had found an aftermarket bracket that was flat or if anyone had tips on how to custom make one that doen't hang down so much. (I'd like to leave the mount on all year round.)
Thanks
Old Aug 2, 2000 | 11:43 AM
MagnumMudMan's Avatar
Arrowhead
I'm not sure about the Sportsman, but on my Magnum I used the mount from Shadetree (I forget the brand name). It only hangs down about an 1 1/2 inches. I leave it on all year as the frame on the Magnum is not the lowest point on the vehicle as it is on the sportsman. If you already have the Polaris mount, I'm not sure an aftermarket mount will work for you.
95wolv
Sep 27, 2024 12:00 PM
EIF
Apr 20, 2017 07:15 PM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
rcappie4
Sep 9, 2015 07:04 PM
toonces
Sep 5, 2015 01:14 PM
