jetting is confusing me
Old May 31, 2004 | 12:50 AM
01ds650's Avatar
Default jetting is confusing me
bike: 2001 DS650, HMF slip-on, RWR CDI, stock replacement K&N filter, elevation 700--800ft
previous setup on carb: stock 40 pilot jet, 185 dynojet main jet, dynojet needle on 3rd clip, airscrew 3.25 turns out.
My local mechanic thought I might be a tad lean on the bottom. So Installed a 45 pilot jet. I also ordered a 175 & 180 Mikuni brand jet(s).
I installed the new pilot but when I went to install the new main I noticed the Mikuni had the larger head on them & would not work
[img]i/expressions/face-icon-small-sad.gif[/img]
So I compared a 180 Mikuni against the dynojet chart. It rated it to be a 192 dynojet. The closet I had was a 190. I installed that.
turned airscrew 3-3.25 out again.
Next I noticed on here DS owners complain about the dynojet needle. I decided to try my stock needle on the lowest notch.
(Both the 180 Mikuni & stock needle I found suggested on the forums).
I went for a ride & found the real low bottom fine. When I roll into the throttle with the rpms medium in say like 3rd gear I get a rich type miss & sputter. However if I go the same ground speed but in 2nd gear & roll into it seems better. When it winds out it seemed to pull hard.
I went back moved the needle to the 4th notch. (next to richest). Upon riding I kinda got the same thing. Maybe not as hard as pull on top end though.
Moved the needle to 3rd notch. Mid felt much "crisper" when rolling from a low RPM. But the top end didn't pull as hard.
This is where I quit for the day.
My mind says it's the needle, being top end doesn't sputter when reved out, but when I had the dynojet needle on the 3rd clip & a 185 dynojet (only a 172.5 mikuni) It ran better as far as reliable & smooth.
So do I try the stock needle on just the second notch? ( lean in the middle I would think).
Try the dynojet needle?
Or just put the 185 jet in & call it a day?
I want power, but reliable smooth power.
I found this comparison chart. It also says the jets not only are flow rated different, but machined & chamfered different.
jet fighters
Thanks guys.
Old May 31, 2004 | 03:39 PM
01ds650's Avatar
bump
Old May 31, 2004 | 03:54 PM
JMAC650's Avatar
Depending on elevation I would start at 4th groove from richest on stock needle, 172.5 mukuni main jet and stock pilot jet. That should put you very close with your mods.
Old Jun 1, 2004 | 12:42 AM
Coyoteman's Avatar
I run a HMF and I ride anywhere from 400 to 1200 ft. My jetting is 170 Mikuni main, needle in the fifth position.
Old Jun 1, 2004 | 01:23 AM
mystereid's Avatar
It's official, I've been duning for over 30 years.
Go back to the dynojet needle. I've switched back and forth 3 times and absolutely love the dynojet needle. You should go with the 185 dynojet ,3rd clip, 45 pilot and tweak the airscrew till the bottom end runs crisp and get a 190 dynojet for cold weather or sea level.
ReconBayou
Oct 31, 2022 05:37 PM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Pissed off
Sep 21, 2015 02:33 PM
