anyone try curtis sparks' 400ex ingition advance key?
Old Aug 2, 2000 | 07:56 PM
allnamesaretaken's Avatar
wondering if it's worth it, might order one! thanks for any insight...
Old Aug 2, 2000 | 10:07 PM
dhines's Avatar
Got one on order - along with a pipe. Heck, for $15 I'll sure give it a try. They claim it makes a noticeable difference.
Dennis
Old Aug 3, 2000 | 09:55 AM
cmchonda's Avatar
What is an advance key? How hard is it to install?
Thanks
Old Aug 3, 2000 | 02:02 PM
GriffsFSR's Avatar
What is the power difference supposed to be like. I am not sur on what advancing the timing will do.I would apreciate all info thanks.
Chris
Old Aug 3, 2000 | 08:45 PM
Dirtddemon's Avatar
Okay guys here is the low down on the advanced timing key, it just a regular key with a lip milled out of the top left side. the key just improves rev a little, i got the x6 race pipe and silencer, air box screen, reinforcing ring for the intake, timing key, air filter, and cdi, major improvement over stock pulls like crazy up through the gears and i can power wheelie when 4th is pinned pretty impresive. i recommend sparks products to anyone. dhines you will like the pipe, they are ceramic coated and look trick. the key is easy to install they send a puller bolt with the key, take off the cover and take out the bolt that hold the flywheel on, take the supplied bolt and thread it into the flywheel and turn it pops right off. tap the old key out and tap the new one in with a hammer, easy as pie. just make sure you readjust oil level after reassembly.
Dirtddemon's Avatar
Old Aug 3, 2000 | 09:28 PM
LDJ's Avatar
LDJ
So do you recommend it, do you think I could tell a difference?
Old Aug 3, 2000 | 09:29 PM
2k400ex's Avatar
timing is everything when trying to extract every bit of power out of any engine. the stock timing curve is very conservative. by advancing the timing engine extra power is the result. usually with a racing machine, you'd want the ability to alter the timing. It can also control your power band, if you got too much bottom end, you can retard the timing and loose . same can be said about advancing it, it will give you more bottom end.
Old Aug 4, 2000 | 09:45 PM
Dirtddemon's Avatar
yep i recommend the key. it will help, when i put mine on with the pipe and other stuff it flat out riped, it was like riding a totally different quad powerwise, you may not notice it as much because you already have a mod machine but mine was totally stock at that time.
metal249
Jul 28, 2015 09:35 AM
NatePerz
Jul 27, 2015 03:27 AM
metal249
Jul 24, 2015 01:00 PM
95wolv
Jul 21, 2015 12:25 PM
D-Hagz
Jul 4, 2015 02:19 AM
