Anyone know who makes longrods?
Old Jun 2, 2004 | 01:31 PM
Shav0's Avatar
Default Anyone know who makes longrods?
Wesico??
Old Jun 2, 2004 | 01:34 PM
daputz's Avatar
hollywood does a lot of long rod engines, give him a shout and he can give you the details. (check the link in my sig)
Old Jun 2, 2004 | 01:36 PM
Shav0's Avatar
Yea i know, I am waiting for a 240 from him right now.
I was just wondering because to compliment the big bore I would like to have the long rod and my motor is apart at the dealer right now and they are waiting for me to tell them what to do. I needed new crank bearings in it and was also going to install a hot rod but now im thinking of maybe a long rod. I don't have the time to wait for a longrod from hollywood.
Old Jun 2, 2004 | 02:47 PM
daputz's Avatar
your porting would have to set up for the long rod, otherwise the port timing will be way off.
Old Jun 2, 2004 | 02:51 PM
garyc660R's Avatar
You do not just install a longer rod and let the happy motoring begin. The top of the piston would be out the top of the cylinder woth everything else the same. Too compensate for the increased rod length either a piston with a revised pic location must be used (higher), or a spacer plate between the cylinder and cases is sometimes used. Longer rod length of a good thing. The piston recieves less side load and the piston dwell time at top dead center is slightly longer, allowing for a more efficient combustion cycle.
Gary
Old Jun 3, 2004 | 10:29 AM
mojavekid13's Avatar
Hey whats up man
you got your bike over to vally already, Thats nuts got it in fast, and they tore it apart some fast to,
Thats crappy that ya need new crank bearings, and that your not getting a Hollywood dirt kit[img]i/expressions/face-icon-small-wink.gif[/img]
Old Jun 3, 2004 | 12:06 PM
Shav0's Avatar
oh im still gettin the hollywood 240..no doubt about that.
Old Jun 4, 2004 | 07:24 AM
Well thats awsome then man
But Holly cow they took your bike in fast over at vally, thats nuts, So what all did they tell ya you neded>?
Old Jun 4, 2004 | 10:47 AM
Shav0's Avatar
seann, Its done right now actually. I am trying to find a way to go over and pick it up. its wierd that they did it so quick, i was surprised when they called me last night.
Turned out it was the crankseal...the bearings were fine i guess but the seal was no where to be found. I guess it got torn out and then ripped up inside the case. When he took the cover off there were little pieces in it.
Old Jun 4, 2004 | 11:52 AM
potentpete's Avatar
you can't just install a long rod crank, you have to use a spacer plate, its not that easy either, the cylinder has to set at the right height.
user493
Aug 13, 2015 12:54 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
toonces
Jul 31, 2015 09:27 AM
Nazz26
Jul 30, 2015 11:51 AM
cSchwartz
Jul 12, 2015 07:42 PM
