Cheapest mod??
Old Jun 2, 2004 | 08:41 PM
wickedkawi's Avatar
Default Cheapest mod??
Hi again folks,umm,what would be the cheapest but best peformance mod for my P650,would you go with a pipe or a full jet kit or both?? Thanks for the good info as usual!
Serge
Old Jun 2, 2004 | 10:42 PM
Kodiac400's Avatar
Hello Serge and well come to atv connection. I think you should start with a filter and jet kit.
Old Jun 3, 2004 | 12:11 AM
MnFriesen's Avatar
start with the clutching...some of the cheapest power can come from it!
Old Jun 3, 2004 | 12:57 AM
tuffEnuf's Avatar
Go with the EPI Outlaw clutch Kit (Black & Red Clutch Springs), and DG-3 Module. If you decide to change your stock filter, you might as well try Nyrocks Muffler mod, Napa Hose or DG snorkel, and rejet. You'll spend approximately $200-250 on parts.
With new found power you'll definately want to replace your front & rear tires and possibly later add the progressive springs to the front (Just changing my front tires to Holeshot ATRs and Mudmachine Triclaws in the rear made a world of difference in handling and traction.[img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-mad.gif[/img][img]i/expressions/face-icon-small-shocked.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-mad.gif[/img]
Old Jun 3, 2004 | 08:11 AM
deerchooper's Avatar
wickedkawi
for the cheapest mods start with.
you need 2 number 4 or 5 nylon washers. these will go under your needles. $.30 each
you need 8, 4mm by 14mm stainless steel allen head screws. these are for your float bowls. $.65 each
you need a 3mm ball end allen wrench, to make it easyer to get the float bowls off. $3.50
you need the next size up main jet ( dont know you elevation) $4.00
now you need more air for all of the above. so go to NAPA and get there hose P.N. 7335. $13. this will replace your stock snorkle.
now that you have all this air coming in you need to get it out quicker. do the nyroc muffler. which consists of cutting the end off your stock muffler and drill 6- 3/8" holes thru all 4 baffles.
you need a 12"- 3/8" drill bit. i think $15.00, then cut out your spark arrestor. then weld the end cap back on.
now that you got it running better. get an EPI black or dalton spring for your secondary clutch. this will make the belt last longer. $ 25.00
for the drive clutch i like the stock 700p spring. gives you a little more all around rpm's. $14.
and there is a list of all the cheapest mods you can do.
go to nyroc web site. you will find all the things you will ever need to know.
_______________
02 650p
nyroc muffler
super snorkle
147.5f/152.5r jets
.033 on needles
dynatek cdi
epi black
700p drive spring
plow
warn 2000lb
home made receiver system
bighorn's
2 dayco 2018 belts coming
wcy2k400ex
May 25, 2001 05:00 PM
HALL650
May 19, 2001 01:23 PM
wcy2k400ex
Dec 3, 2000 04:09 PM
moinfar
Oct 12, 2000 08:03 PM
mudmanatv4x4
Sep 2, 2000 04:40 PM
