Why does my 440 heat up so fast ???
Old Jun 2, 2004 | 09:22 PM
needa440ex's Avatar
Default Why does my 440 heat so fast ???
Is it normal for a 440 to run hot ,,,,main jet 182
i have stock sprockets on it now ........................ what should i do to prevent from wheelling so much need more take off
Old Jun 2, 2004 | 09:55 PM
cals400ex's Avatar
Default Why does my 440 heat up so fast ???
a 440 will run hot. just becasue your mainjet is huge, you could be lean on your pilotjet/fuel skrew and/or needle.
you could add an aftermarket oil cooler, scoops and a colder plug to cool it down a bit. for better take-offs, learn how to use the clutch better, get an extended swingarm, or put heavier tires on the front.
Old Jun 2, 2004 | 10:29 PM
TractorPacker's Avatar
Do you have a balloon?
Try a 40 pilot jet, possibly bring your main down, also. How hoy is it getting. Is the pipe glowing?
Old Jun 2, 2004 | 10:52 PM
Yamaha4eva's Avatar
ah so u did get it bored!, well its air cooled for one
Old Jun 3, 2004 | 03:19 AM
cals400ex's Avatar
he is running a 440
Old Jun 3, 2004 | 10:18 PM
Yamaha4eva's Avatar
he is running a 440
ummm, wow that made no sense buddy.....he posted earlier about getting his honda bored and i didnt know he got it done lmao and the 400ex model is air cooled, so what gives?
Old Jun 4, 2004 | 12:31 AM
CroBiker's Avatar
get some air scoops, a bigger oil tank, and increase the jetting. because of the big bore it will run hot, but u might be running lean too. try slipping the clutch more when u get going, if u go down on gearing, then u lose on the top end. most people with big bore quads do go to an extended swingarm to help control the wheelies. good luck with ur machine!
Pehter
Oct 3, 2024 11:00 PM
ReconBayou
Oct 31, 2022 05:37 PM
Jeff Roper
Feb 1, 2022 11:48 AM
Sw00p
Sep 24, 2015 02:50 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
