Welding a bead
Old Jun 3, 2004 | 01:26 PM
pinheadedjoker's Avatar
Default Welding a bead
Curious i pulled my raptor oil tank off because it was leaking and I was looking at it and on the bottom not the drain plug but the other oil sucker plug.. but around that it leaks.. would welding a bead around this part of it be a cheap/ but good idea?? rather than getting a whole new aftermarket tank?? or will the weld just end up busting and what not??
thanks
Old Jun 3, 2004 | 01:51 PM
kurt14's Avatar
well what kind of welder? You'd have to keep it cool so it wouldn't warp and hope the slack don't get inside you'd really have to clean it afterwards. Me personally i would try jb kwik weld first. If you decide to weld it you'd have to repaint it in order to get it's looks back i mean i could do it but i know alot of machinist that i'd get to do it instead.
Old Jun 3, 2004 | 01:53 PM
HoundDog06's Avatar
I had the same problem with my oil tank cracking. The problem with running a bead would be the heat expansion that close to the oil uptake could cause the o-ring to not seat good when you put it back together. Mine was still under warranty and I got a new one from my dealer. If I were you, I would start watching ebay for a good aftermarket tank. Might be a good time to think about a larger capacity one.
~HoundDog
Old Jun 3, 2004 | 02:18 PM
any other oppionions??
Old Jun 3, 2004 | 02:27 PM
bad660r's Avatar
I like my Pingry tank. Pingry Oil Tank My stocker cracked just as you're describing. I would take it to a good welder if you stay with the stocker. I don't see why they couldn't fix it. I just liked the idea of the extra oil, looks killer, and the cooling holes with the Pingry. I've been wanting to fix my stocker as a backup in case something happened to my Pingry, or my other Raptor's oil tank takes a dump.
Old Jun 3, 2004 | 02:47 PM
OUCH 274 is a hard hit how do these rate?? um tank? i found a differnt one on ebay earlier this week for around 130 it was the um also
Old Jun 3, 2004 | 02:49 PM
bad660r's Avatar
Looks good to me. I like the heat sheild. I've never checked into that, but it is closer to the header than stock.
Old Jun 3, 2004 | 03:44 PM
i need to know if i took it to a welder could they fix it well?
Old Jun 3, 2004 | 04:15 PM
yes no maybe so?
Old Jun 3, 2004 | 04:19 PM
Eric250EX's Avatar
theres always duck tap. lol j/k. i like the one you found on ebay with the heat sheld. that one seems more worth it than the one on pingry
