oil filter need help fast
Old Jun 3, 2004 | 03:11 PM
devilstalin's Avatar
Default oil filter need help fast
i need to know if u can change ur oil filter on a 400ex with out emptying the oil tank
Old Jun 3, 2004 | 06:17 PM
emac's Avatar
a trick i learned for working on my dirtbike clutch is that if you lay the bike down on its side you can work on it without draining the oil. I am guessing that you could do the same thing with a quad if you realy had 2, but y change the filter without changing the oil? your just runing the same dirty oil through your new filter.
Old Jun 3, 2004 | 08:51 PM
well i just changed my oil and the filter but i think i might have put the filter in backwards so i want to check it
Old Jun 3, 2004 | 09:08 PM
emac's Avatar
ya id just try tipping it sideways and checking it out...... better safe than sory[img]i/expressions/face-icon-small-smile.gif[/img]
Old Jun 3, 2004 | 09:19 PM
ya thats what ill do thanks a lot man
Old Jun 4, 2004 | 02:13 AM
cals400ex's Avatar
you don't have to drain the tank. you will loose a bit of oil from where the filter goes on but that is it.
Old Jun 4, 2004 | 03:49 AM
thanks cals
Old Jun 4, 2004 | 11:37 AM
Trevor's Avatar
Years ago when I was young I put the filter in backwards on my father's 86 350 4x4. It destroyed the head and cam so don't run it and check to see if it is right. The oil you'ed lose is cheaper than a new head! Also never buy aftermarket filters !!! The honda ones have an arrow on them to show what way they go in and I also herd that the aftermarket ones change the oil pressure but I don't know if that is true?
nastyblaster100
Sep 13, 2015 01:19 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
black798
Sep 9, 2015 07:42 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
