87 250r reeds
Old Jun 4, 2004 | 11:54 PM
jcas's Avatar
Default 87 250r reeds
What's up guys, quick question. I was checking the reeds on my 87 250r and noticed that one of the reeds on the bottom side of the reed cage is chewed up on the top. It still closes solid, but could it cause a problem? If so, would the carbon fiber boyeson reeds be a good replacement? Thanks
87 250r
83 atc 250r
81 atc 200
Old Jun 5, 2004 | 02:40 AM
trapperb1's Avatar
Are the reeds in there now steel with 3 pedals? If so they are oem.
If they still close solid, they're still OK.
I run the Boyesens just for a little extra throttle response and they screw right on the stock cage.
Old Jun 5, 2004 | 05:08 PM
theHulkamaniac's Avatar
If your at all concerned they may be worn change them. If original change them, those puppies are almost old enough to vote. Their effectiveness would be quite deminished.
I run the delta 2 v-force on my r. There excelent, zero problems. Or a cheap alternative, boysen carbon reeds.
Old Jun 6, 2004 | 11:35 PM
jcas's Avatar
Thanks for the feedback. They were the oem ones, and they were pretty loose compared to the new carbon fiber boyesons. The bike seemed hard to start at first, maybe cause i had it torn apart for a few days. Is this normal? Also, on the instructions it says that the bike may run rich with the new reeds. Can I offset this by taking the lid off the airbox? Always looking for more power........
87 250r
83 atc 250r
81 atc 200
QuadRiders
Oct 22, 2015 04:13 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
Halffast17
Sep 11, 2015 02:30 PM
