help with my 200x
Old Jun 6, 2004 | 01:38 AM
Pudgedawg007's Avatar
Default help with my 200x
well i got a deal on a 200x and the lady told me her son blew the engine and had gotten a new one off of ebay it just needed to be intalled so i switch engines and reconnect everything but when i tried to kickstart it nothing i don't know much about these atc enginesbut any help is apreicated
jeremy
Old Jun 6, 2004 | 03:25 AM
Blazerone22's Avatar
Do you have spark? are you getting fuel?
Old Jun 6, 2004 | 04:42 AM
Jake223's Avatar
Have to ask,but are you getting the basics? Fuel,spark,compression? Switch is to "run"??
Old Jun 6, 2004 | 08:45 PM
ok today i pulled the spark plug and i have spark it seems to be getting fuel because when i was kicking it to check for spark i smeeled gas from the spark plug hole and the switch is in run postion i kick it it seems like it's gonna start but doesn't
Old Jun 7, 2004 | 01:09 AM
Iwant2drivefast's Avatar
if everything else seems to check out I would check to make sure the timing is right. And make sure the carb is set right.
Old Jun 7, 2004 | 12:55 PM
ThrashAndCrash's Avatar
Check the valve clearance, .003 in.
Compression 156 psi +- 14 psi
Plug gap .024- .028 in
Do not just asume you have fuel. Check the filter in the petcock. You may also want to pull off the fuel bowl to see if there is any varnish in there.
Old Jun 7, 2004 | 09:55 PM
ok how do i check the timing i know how to chevk it on a car but.........i have a manual i guess i should open it up and read insted of bothering you guys with my problems thanks for the input fellas
jeremy
200x hill climber
Ask the Editor
Jun 10, 2015 11:11 PM
88Warrior
ATC 3-Wheelers
Aug 7, 2001 07:27 PM
hrc200x
ATC 3-Wheelers
Feb 7, 2001 08:46 PM
bigmanm
Jun 28, 2000 10:34 PM
200X
ATC 3-Wheelers
May 24, 2000 10:47 PM
