atc200 motor in atc 200x frame
Old Jun 26, 2000 | 12:33 AM
bigmanm's Avatar
If anyone knows about the little rubber spacer between the cylinder and carb. Well I put my atc 200 motor in a 200x frame and everything bolted right up except for the way the carb goes in. It hits the back shock and wont fit. Does the 200x have a different shaped or angeled intake hose between the cylinder and carb than the atc 200. If i purchase a 200x intake thing or what ever they call it will it allow me to bolt up my carb to my atc 200 motor in the 200x frame.
I bolted the carb straight to the cylinder with out the spacer type intake. And it fit good except it over heated my carb and turn the gas into a vapor and stopped running good when it got hot so I will have to find some way to bolt up my carb.
Old Jun 28, 2000 | 10:34 PM
Keenan's Avatar
I have done this engine swap before as has many others. Yes, get the 200X intake manifold and that will line up your carb the way it should be.
Valder
Nov 28, 2020 07:38 AM
fd24
Jan 16, 2019 08:59 AM
bigred20653
Oct 2, 2015 10:05 AM
caveeagle
Sep 19, 2015 01:20 PM
JDawg8309
1) Engine problems..
Sep 12, 2015 02:24 PM
