question about uni vents
Old Jun 7, 2004 | 12:02 AM
PredBoy's Avatar
Default question about uni vents
Just wondering if the uni vents will give some performance and is it worth it? Also will I have to re-jet my carb?
Old Jun 7, 2004 | 12:11 PM
speeeedy's Avatar
yes, yes and if you have not jetted yet with the k&n and slip on you should rejet for sure
Old Jun 7, 2004 | 04:11 PM
PredBoy's Avatar
I think the quad is jetted correctly because it is running superb.[img]i/expressions/face-icon-small-smile.gif[/img] But do I need to jet it again cause of the uni vents?
Old Jun 7, 2004 | 04:18 PM
speeeedy's Avatar
if you had it jetted once after the mods u could be ok. i took out all of the filter stuff they put on the bottom and put in about 9 or so of the small filters. i had mine jetted after all of my mods were put on. just becouse it feels right doesn't meen it is.[img]i/expressions/face-icon-small-wink.gif[/img]
Old Jun 7, 2004 | 08:28 PM
badazzpred's Avatar
predboy I would assume your in the 0 to 6,000 ft elevation range I also just installed 5 uni vents in my stock air box and I am running the k&n panel filter with a white brothers /pure polaris slip-on exhaust 8 disks and spark arestor I spoke with ben bettis over at rath racing and he told me with my mods that I should go to a 50 pilot jet between a 172.5 or a 175 main jet and turn the air/fuel mixture screw all the way in and then turn it back out 1and3/4 turns and I will be good to go.............................sounds like you pretty much have the same mods as I do so maybe run with that Idea......................
ReconBayou
Oct 31, 2022 05:37 PM
shimanok2
Jan 29, 2016 07:37 PM
bigred20653
Oct 2, 2015 10:05 AM
bigred20653
Sep 19, 2015 02:11 PM
bvolks
Sep 13, 2015 12:57 PM
