Popping out of gear
Old Jun 7, 2004 | 09:42 AM
dodgepower's Avatar
Default Popping out of gear
Hey yall i took the scrammy over to a mx park and was riding this weekend....right at the end all of a sudden it started popping out of gear. Not just when was jumping...Any ideas?????????????????????
Old Jun 7, 2004 | 02:45 PM
BigBadScrambler's Avatar
Did you check the linkage? If its not the linkage, then it sounds like something internal[img]i/expressions/face-icon-small-frown.gif[/img]
Old Jun 7, 2004 | 04:13 PM
dodgepower's Avatar
Well i looked at the linkage everything seems there. havent check to see if any bolts are loose but im thinking is internal too.
Old Jun 7, 2004 | 05:00 PM
CED's Avatar
CED
Sounds like the shft fork in the tranny,it is probably flared open.
Old Jun 7, 2004 | 05:28 PM
dodgepower's Avatar
Whats the easiest way to get too it ced?
Old Jun 7, 2004 | 06:16 PM
CED's Avatar
CED
You will have to split the tranny,it really isn't that hard.Split it and take a look inside.Try everything else first.
Old Jun 7, 2004 | 06:28 PM
ftwflh's Avatar
Before jumping into your tranny check the "bell crank" where the linkage hooks up to.They strip out and can cause this too by not letting it shift all the way into gear.
Old Jun 7, 2004 | 06:33 PM
dodgepower's Avatar
Aight yall thanks will check out the one fwt said first cause easier if not will crack the tranny oh im gonna hate that[img]i/expressions/face-icon-small-smile.gif[/img]
Old Jun 7, 2004 | 06:53 PM
1fastpolaris's Avatar
Mine is having the same problem., but only sometimes. It only happens when i get about half way up the hill ( this is at comp hill at the dunes ). I checked all the linkage and looks like i am going inside. This all happened when i took out reverse gear. Hope it is not related anyhow. Well see
merryman
Sep 6, 2015 10:20 AM
Haakon
Aug 24, 2015 01:54 PM
mbkirk
Aug 14, 2015 08:20 PM
ghost civic
Jul 19, 2015 10:13 AM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
