500 Auto shift adjustment???
Old Jun 7, 2004 | 08:59 PM
campin's Avatar
Default 500 Auto shift adjustiment??
I have a four week old 500 auto and occasionally when I shift from low to high (after stopping) the transmission will click gears as if not all the way in gear. If I move the shift lever slightly toward low then place it back to high everything is OK. I believe the linkage requires a bit of adjustment. Is this something I can do? If so please advise.
Thanks
Old Jun 8, 2004 | 12:00 AM
1tonchev's Avatar
Default 500 Auto shift adjustment???
Your idle speed is to high, try adjusting your idle down a bit. Mine did the same thing.
Old Jun 8, 2004 | 01:31 PM
Catterman's Avatar
Got Milk!
Blaming Guns For Crime Is Like Blaming a Spoon for Rosie O'Donnell being Fat!
Thanks
Mine did the same thing too when it was new. I now have just over 200 miles on it and that is no longer a problem, it went away. If you have less then 150 miles or so I would just give it some time to break in.
Old Jun 8, 2004 | 04:42 PM
freetrapper's Avatar
My new AC 500 Auto is less than a month old as well. I have about 100 miles on it and I have the exact same problem. It has happend a few times and one time I could not get it to go into any gear so I shut it off and kind of rolled it back and forth a little and then started it and tried again. All went fine for the rest of the day.
Im taking these guys advice and giving it a bit before I complain to my dealer.
Good Luck and post a few picks of your new cat.
Old Jun 8, 2004 | 09:25 PM
MnCat's Avatar
It too happened with mine when new. Follow the suggestion of turning down your idle. Adjusting your linkage will only cause other problems.
Old Jun 8, 2004 | 10:18 PM
campin's Avatar
Thanks to all who responded to my question. I've been lurking on this site for several months and just recently bought my own Lime Cat. I knew if I had any problems I could count on this group for a straight answer. I have located the "very handy" idle adjustment **** and will back off on the idle just a bit and see if this helps. Oh, Myself and two buddies are heading to Gilbert, WV. this Saturday for five days on the Hatfield Mccoy trails. I will post some pictures of our trip.
Thanks
2004 500 Auto Lime Green, chrome wheels
Warn winch
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Sep 9, 2015 09:38 AM
craacker
Sep 9, 2015 04:32 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
