gas mixture screw
it changes wether it is rich or lean. i think it should be around 1 turn out, but i truly have no idea. i think if its too far out of that rance you will need to change jet size. i've never messed with it, i'm jsut saying what i've heard. i could be wrong also.
From what I've been told the mix screws function depends on where it's located.
If it's on the engine side of the carb then it's a fuel screw, turning out means more fuel. If it's on the filter side of the carb then it's an air screw and more turns out means more air.
I asked this question about my Warrior on here not long ago .. some time earlier this week I believe .. or late last ..
I'm in the process of rejetting now ...
This article is about motorcycles, bur the information is still correct for atvs too.
carb basics
carb basics
Oct 10, 2015 10:20 AM
