installing durablue axle
Old Jun 10, 2004 | 09:29 PM
ringer's Avatar
Default installing durablue axle
I installed a durablue eliminator axle.It is wider on the right side then the left.I go through the directions and I cant see where I did anything wrong.The c clips are on and the axle is tight.The posi nut tightens off the right c clip right?Do you just use the spacers to even them out or is it installed wrong.
Old Jun 11, 2004 | 10:44 PM
Wookie's Avatar
You should be asking Durablue.
Old Jun 12, 2004 | 08:34 PM
blue250r's Avatar
Are the splines on the axel the same distance from the end of the axel on both sides if not u probably have it in the wrong way round
Im not sure if there is an ofset on your machine or not check the old axel and the new.
ReconBayou
Oct 31, 2022 05:37 PM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
2many2ride
Sep 27, 2015 04:35 AM
toonces
Sep 5, 2015 01:14 PM
