Need carb help on a '96 Wolverine
Old Jun 13, 2004 | 12:39 AM
RaptorRacer1's Avatar
Default Need carb help on a '96 Wolverine
Hey guys, my raptor was too fast so I sold it and bought an old beat up Wolverine.
Just kidding. I am trying to fix up my step-dad's old '96 Wolverine and I can't get it to start. I have a few questions related to the carb.
1) What are the stock jet/needle settings and screw settings? Everything is completely stock.
2) There is some sort of breather hose coming out the top of the carb, but I don't see anywhere in the airboot or airbox to attach it. Is this hose supposed to be connected somewhere?
It will roll over just fine. There is spark at the plug. Clean gas in the tank. I am almost sure this is a carb issue. Any suggestions? Thanks,
RR1
Old Jun 13, 2004 | 12:00 PM
LotusPosition's Avatar
There are couple different specs on the carb, depending on where it was sold (main jet). In my service manual: main 135, pilot screw, 2 turns out from lightly seated, needle, clip on third notch, float heighth,11.4-14.4 mm (.45- .53).
The carb has a vent hose that is generally just routed through the rubber flap around the airbox intake, along with a couple other breathers. Make sure the vent is not plugged. Perhaps the carb needs a good cleanout?
Old Jun 13, 2004 | 12:05 PM
CTATV's Avatar
remember the older wolverines till 96 or maybe 97 had 36MM carbs the newer wolvs have 34mm carbs just somthin to keep in mind
Old Jun 13, 2004 | 01:43 PM
AFAIK, only the 95's had the non cv carb.
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
