carb help
Old Jun 13, 2004 | 05:41 PM
sledhead1's Avatar
Default carb help
Can someone help me. The pilot screw in my carb was siezed and when i got it out i buggered up the threads. Dose anyone know the thread size and pitch? I think it is 7mm but I can not find that tap at any local machine shop or anywere else. I some please tell me what the thread is befor I order a tap?
Old Jun 13, 2004 | 11:41 PM
sledhead1's Avatar
Default carb help
Can someone please help
Old Jun 14, 2004 | 02:01 AM
hondabuster's Avatar
Default carb help
The easiest way to know the thread, is get a new pilot jet, and measure it.
Measuring the major dia of the thread, will give you the first number, and it will be metric, and should be very close to nominal (whole number), like 7mm or 6mm.
Then measure the distance, with a calipher, from one crest of a thread to the next crest. This is the pitch, which gives you the second number. If the distance is about .04", thats 1mm,.... if its about .06", that will be 1.5mm, and so on. Youll end up with something like 6mm x 1,and thats the tap size. If you post what you end up measureing, ill be able to help you figure out what tap to get.
Old Jun 15, 2004 | 01:28 PM
sledhead1's Avatar
Default carb help
well from what I have measured it is 6mm x 0.5 thread. It is extra fine thread. All the taps I have found so far are 6x1 or 6x.75. I will try a machine shop supplier today
Old Jun 15, 2004 | 02:34 PM
Default carb help
Itll probably cost more to ship than the tap costs, so you may want to brouse the catalog and see if theres other stuff you want.
m6 x .5 tap
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
